Rumour Mill: First AMD Barcelona numbers!
K404
IF (and thats a big IF) these numbers are true.....AMD, I missed you!
Surfaces from an alien spot
By Charlie Demerjian: Wednesday 28 February 2007, 11:58
IT LOOKS LIKE the first Barcelona number have surfaced at Seti@Home of all places. If you look at BoincStats, you will see what I mean.
Look at the number one CPU, an 'unknown' AMD CPU that has no listed clock but two cores. On the last column, average credit per CPU, it kind of kills the Intel CPU in the number two spot on performance.
Please bear in mind that this is just one app, is based on a semi-anonymous hackable format, and can be skewed in all sorts of ways. That said, it is an interesting data point.
Thanks to Dresdenboy at Aces for the link. µ
http://www.theinquirer.net/default.aspx?article=37907
Maybe it's K10 dual core variant,maybe it isn't.But if it is,it may be working at low clocks(ES) and producing awesome results^^.
Here are the results:
http://www.boincstats.com/stats/host...sah&st=0&or=10
1 AMD Athlon(tm)/Opteron(tm) CPU-model unknown 2 278,442.67 2,857.89 139,221.34 1,428.95
2 Intel(R) Xeon(R) CPU X5350 @ 2.66GHz 2 68,561.65 2,256.93 34,280.82 1,128.46
3 AMD Athlon(tm) 64 FX-70 Processor 2 39,195.18 1,984.78 19,597.59 992.39
4 Intel(R) Xeon(R) CPU X3220 @ 2.40GHz 4 689,678.66 3,450.13 172,419.67 862.53
5 Intel(R) Xeon(R) CPU E5335 @ 2.00GHz 5 106,276.05 4,133.46 21,255.21 826.69
Some more number interpolating:
New Opteron @ ? (für die Rechnung werden übertriebene 3GHz angenommen)
1457 / 3000 = 0.4856
1457 / 2600 = 0,5603
1457 / 2100 = 0,6938 (estimates based on the expected release clocks)
X6800 @ 3,784GHz
1503 / 3784 = 0.3971
A64 FX-60 @ 2,94GHz
755 / 2940 = 0.2568
NONE of this is confirmed, theres several things that can be wrong with this..e.g...why the hell is an ES holder running SETI?
LOL
More info:
EE Times: Latest News
AMD tips quad-core performance
Rick Merritt
EE Times
(02/28/2007 7:03 PM EST)
SAN FRANCISCO, Calif. — Advanced Micro Devices upcoming Barcelona processor will sport floating-point performance 42 percent higher than Intel's current top-of-the line CPU, the Xeon X5355 also known as Clovertown.
The news marked the first performance numbers AMD has provided for the chip that packs four Opteron cores on a single die and will be in production this fall. AMD also demonstrated working versions of its next-generation graphics chip the R600 to be released by the end of June.
AMD has been under pressure from archrivals Intel and Nvidia. Intel is shipping multiple quad-core processors using a system-in"package approach, claiming it has retaken the performance lead in x86 CPUs. Nvidia shipped a new generation graphics controller last fall, a move the graphics division of AMD has not yet answered.
Mario Rivas, general manager of AMD's microprocessor group, said Barcelona will provide a double-digit leap in integer performance over the quad-core Xeon, though he declined to be more specific. Henri Richard, chief of sales and marketing at AMD, said Barcelona will have a significant integer performance lead over Intel's quad-core chips.
Although the floating point advantage is significant, few applications outside high performance computing and video encoding make use of it. Nevertheless, analysts were positive on the news.
"I thought Richard's comments were a strong vote of confidence in the product," said Nathan Brookwood, principal of market watcher Insight64 (Saratoga, Calif.).
"Virtualized Web servers don't use floating-point processing, but if AMD is seeing integer performance gains over Intel in double digits, that's a positive for them," said Dean McCarron, principal of Mercury Research (Cave Creek, Ariz.), referring to the most mainstream application for Barcelona.
Separately, AMD gave one of the first public demos of the R600, its next-generation graphics controller that uses 320 multiply-accumulate units. The company showed a Barcelona-based system using two 200W R600 graphics cards to hit a terabit/second benchmark.
Release of the R600 has been delayed "a few weeks" so that AMD can roll out a full suite of graphics chips covering multiple market segments for the latest Microsoft DirectX 10 applications programming interface. Rival Nvidia rolled out its high-end DX10 graphics controller, the GeForce 8800 last fall but has not filled out its product line with midrange and low-end parts based on it yet.
"As soon as AMD makes their DX10 announcements, I am sure we will hear about competing products from Nvidia," said McCarron.
In addition, AMD announced a new desktop chip set, the first from the ATI division since the merger last fall. The AMD 690 sports an ATI Radeon X1250 graphics core and a new video decode block. It is also the former ATI's first chip set to support the HDMI video interface with HDCP copy protection for high definition video.
Ten motherboard makers said they will ship as many as 30 products with the chip.
"They put a lot of emphasis on home entertainment with this chip set," said McCarron. "It's a stronger graphics core than they have used in the past," he added.
11 page reports on Barcelona improvments: Not easy reading, but DAMN its well written, no fanboi-ism and makes me feel pretty good about AMDs new CPUs
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2939&p=1
So if someone can read between the lines and tell me what amd are promising:
More instruction per clock? (like Athlon XP)
Higher Clocks?
Lower Power?
Core 2 beating performance overall?
core 2 quad beating performance?
Higher clocks? (sooo important lol)
Not physically higher clocks. Release clocks are 2.1-2.3GHz for the Quads so I hear. Dual-core will come later at up to 2.9GHz clocks, By the time the duals arrive (possibly failed quads) AMD hope to have ramped clocks so stock Quad core speed wont be far behind. Physical clockspeed doesnt matter. You know that.
definately DEFINATELY improved IPC. Its not possible for it to be worse!
Potentially lower power- once the full Barca boards are out, independent voltage and eventually clock options will be available.
Cant comment on actual performance, but it sure as hell looks good on paper.
