hoofhearted4
so i wanna get some of these fans. i want to connect them to this so i can turn them off. and its going to be in this case.
i highly doubt the cables are long enough to be routed through the back of my case and into that adapter in the back of my case. so what do i need to make those cables longer?
as a note, that case has a fan cable hub of sorts in the back. its not a fan controller, as it doesnt control fans, just a place for you to plug all your fan cables in and keep them need, organized, and in one place. is it possible to hook the Hydra fan switch to that little hub, and the fans to that hub?
i appreciate your help all
