Review: Das Keyboard Professional Silent
Stryker64
Introduction:
Earlier on this year I reviewed the Razer Blackwidow Ultimate. Which was a brilliant keyboard that I really enjoy using. Having two computer it was really annoying switching from a mechanical to membrane keyboard, as membrane ones felt really mushy.
Today I'll be looking at my recently purchased DasKeyboard Professional Silent using Cherry MX Browns and a minimalist design.
Technical Specifications
First Looks
The packaging for the keyboard is quite simple as you can see with a nice big picture of the keyboard at the front and some technical specifications at the back.
The keyboard itself is wrapped snugglie with a bit of foam to protect it from minor bumps and scratches.
The keyboard itself is made from a glossy plastic, which will no doubt attract fingerprints, however DasKeyboard were smart enough to realize this and added a microfibre cloth to keep it nice, shiny and clean. This particular model comes with lasered keys that are sculpted for extra comfort. The lasered lettering also means the lettering will be a lot more durable than the commonly utilised pad printed keys, and if you are paying $150 AUD, which is enough for a HD6790, you would want your keyboard to last.
There are also alternative models that feature Cherry MX Blues and with or without lettering.
The keyboard comes with a 2 metre or 6.6ft long and a USB to PS2 adaptor. If you are given the choice between the two PS/2 is the way to go since it supports full nkey rollover, meaning you can press every key down at the same time and all the keys will register. If you are using it in USB mode you will be limited to 6 keys at the same time. The other cable connects to the USB2.0 headers at the side of the keyboard. The USB headers on this particular keyboard will run at USB2.0, but if you plug in two devices the bandwidth will be split.
The Caps Lock, Num Lock and Scroll Lock LEDs are nicely concealed at the top right and can only be seen when they are activated. Not when you look look at it from the side you can just glimpse the blue LED underneath.
Testing
Typing on this keyboard is a different experience, it's distinctly different from both the Blackwidow , which has Cherry MX Blues and your regular membrane keyboards. The keys on this keyboard require very little force to push down yet they do offer nice tactile feedback when typing, and is really quiet unless you bottom out the key, since for mechanical keyboards you only need to compress the keys halfway. The only thing that's really bugging me is if you press down on the spacebar really hard you a weird hollow metal echoing noise, it's also audible from the enter and other long keys, but it's most prominent on the spacebar, and it's a high pitch ringing, which I personally find really annoying. But when it comes to the actual feel of the keys they are extremely comfortable to type or game on.
The lettering on the keyboard is quite prominent and can be easily felt when you rub your hands over the keys. The keyboard also has my preferred layout without the L shaped enter key. The keyboard itself does lack features, as there aren't any drivers, macro keys, backlighting or LCD Screens, but no everyone needs does with their keyboards. Also This keyboard does lack media keys, so no skipping songs in the middle of a BF:BC2 game.
The DasKeyboard Professional Silent is a wonderful keyboard to type on. It combines a minimal design with the lack of 'gaming' features such as backlit, macro keys or LCD screens. This keyboard is probably for those purists that don't want any of does gimmicky features and at the end of the day, all the keyboard needs to be is, well a keyboard and this is definitely a really nice keyboard to type on. Using this keyboard you can not only type on it comfortable, but if it is in PS/2 mode you can also roll your face on the keys and it will register everything.
However this keyboard also has its flaws. The glossy plastic looks great, but does attract fingerprints, however it's definitely more resilient to prints when compared to my BlackWidow. The main issue I have with the keyboard is the echoing/ringing spacebar, now since it is of a higher frequency, older users probably won't be able to hear this ringing noise, but I however can, so I'll definitely be wearing headphones when using this keyboard. Finally there is the price, this keyboard is priced on par with the Razer Blackwidow and Logitech G19, yet doesn't have any of their features, but whether or not that matters is up to you, personally I don't care, but some might.
Overall this is a great keyboard one only want to use their keyboard as a keyboard, not as a a pretty light show or something with a screen to check their CPU temperature on. The keyboard is fairly solid, with the only real issue being the weird ringing spacebar, which will hopefully disappear through some extended use.
Pros:
Mechanical Keyboard
Full N-Key Rollover
Sleek Looks
Mediocre:
Glossy surface requires occasional cleaning
Con:
Ringing Spacebar
Price!
nice review Zeals. obviously this is a high end keyboard reviewed here. How would you compare this against something in similar price braket say the Steel series 7G/6Gv2? obviously only if you have experience of those keyboards of course.
Well the only keyboard I can compare it with is the Razer Blackwidow Ultimate. This keyboard does feel a more solid than the Blackwidow when typing and the actual key caps feel really solid, and make the Blackwidow keys feel a bit cheap in comparison, I believe they use different plastics, but I'll need to confirm that. Also this is lower maintenance since it's harder to get fingerprints on the plastic. On the Blackwidow you can even leave noticeable marks on the keys as well as the glossy plastic!
So if you don't want any backlit or macro keys I would probably choose this over the Blackwidow. There's also a version of this with the same keyswitches as the Blackwidow Ultimate if you prefer having an audible click when you press the keys and a bit more tactile feedback, personally I prefer Cherry MX Browns which are used on this keyboard. It would be interesting comparing this to another keyboard of a similar price range such as the SteelSeries ones, since they don't spend money on 'gimmicky' features.
Nice keyboard, shame about the pinging...
Well from the research that I've been doing on the matter, the pinging appears to happen to Cherry MX Plate mounted keyboards, which both the DasKeyboard and Razer Blackwidow I own use. Judging from the article I read it appears to be fairly rare, so my keyboard is either damaged in shipping, a faulty or certain people just can't hear it due to the frequency of the pinging.
After some testing on the my Blackwidow I notice that it also pings, but it isn't nearly as loud as my DasKeyboard, but that might be due to the loud click drowning out the ping.
Great review bud,i'd love to have one with backlit keys but the price is a bit well a lot out of my budget for a keyboard it's ont he wish list though!
Well mechanical keyboards are designed to like 10 times longer than your average keyboard, so you can see it as a long term investment.
Though expensive, I'd definitely have to say its a wishlister for me. Course, I"m kind of still having fantasies about the earlier DasKeyboards with the blank key setup. Nicely done review. Tight, informative, and well rounded.
The blank key setups can also be purchased, but they cost the same as the ones with letters etched into them, which was why I chose ones with letters on them
Also thanks
Question about your DAS
I just bought a das last week with brown swiches. My problem is that the keys are a little to...sandy. When i press the a key slowly i can feal de plastic rubbing, it's almost abrasive. I don't know to explain is but it is not smooth, not like a new logitech g11. Can you tell me how is yours?
i have one of the das ultimates which is the one with the blank keys and i can say it is the best keyboard i have used hands down.
