So I cannot source any 120 mm, transparent white led fans locally and do not want to import any. There are on the other hand a number of blue led fans available and I want to replace the LEDs with white ones. There shouldnt be a problem with the resistors seeing that blue and white leds have similar operating characteristics. Now, what I would like is advice as to which of the following fans I could best use for this:
Antec Tricool 120mm Blue LED
Coolermaster 120 mm Blue fan with on/off
Zalman ZM-F3BL
Lian-Li CF1409A
What I am looking for is a quiet fan to pull air into my case from the front and it must not be too involved to remove the leds. The problem is also that none of the pictures that I found online show how the led is mounted and the size of the leds.
I did peek inside a box Coolermaster fans and I think the 120 mm fans make use of the same design as the 140 mm that my 692 case has. I don't see how im going to remove those leds?
I couldn't find any relavent topics so I'm trying here.
PS: Merry Christmas
Zalman ZM-F3BL
Lian-Li CF1409A
PS: Merry Christmas
