barnsley
born in a.....
This is a build I am helping a friend do, he needs it to eventually support SLI'd 670s and it needs to be good for gaming and work in UDK (light rendering and stuff). The budget is around £600 (the closer the better). He already has the ram (8gb corsair xms3 1600mhz) and a 670 that were previously purchased for an upgrade that never happened.
This is what I came up with: http://uk.pcpartpicker.com/p/1NrtU
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor- £175.00
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler -£23.98
Motherboard: MSI Z77A-G45 Thunderbolt ATX LGA1155 Motherboard - £94.00
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk -£71.99
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive- £62.99
Case: Inwin GT1 Black ATX Mid Tower Case - £55.00 (placeholder case, probably won't use this
Power Supply: SeaSonic M12II 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply- £88.50
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)- £67.19
Total: £642.84
I need some advice on it, in particular the use of a xeon. I've never specc'd a build up with one and I chose it as I was told it is a 3770 without the gpu? It also made the build just in budget. The psu is overkill for a single card system but as mentioned before another 670 will arrive after christmas.
Any improvements/ideas welcome.
-Edit updated list to have a E3-1230 v2-
Total: £642.84
