paulstung
I'm looking at buying a HD 7850 , with the intention of adding it into my loop , but which ones are reference . The cards I'm looking at are HIS HD 7950 , or , HIS HD 7950 IceQ X² BOOST and finally the XFX HD7950 Double Dissipation . According to the EK configurator they all support a full cover block in one form or another . But I'm looking at an Alphacool block . Should I just use the EK config , as a guide for any other make ? Thanks for reading .
Please remove problem sorted .
