Recommend me a screen for my rig
p1987
I currently have a 19" wide screen. What would be the maximum size screen that I would be able to use without losing fps?
Would anyone be able to recommend me a decent screen for a good price?
Regards
Size has nothing to do with it. My 17" laptop screen has more pixels, and is therefore more strenuous to run games on, than a 120" hypersupermega TV - it's all about the resolution.
So, if you don't want to experience any frame drops from upgrading your monitor, ensure that the new monitor has the same resolution as your current one.
What's your current monitors resolution? I'm guessing 1440 x 900? If so try and find an IPS panel monitor at that resolution.
I wouldn't recommend a screen with less than 1080p, lower resolution isn't really worth buying imo. I'd recommend a monitor with an IPS panel, something like the Dell U2312HM as Saltire35 said or the Asus PA238Q.
I'd add the LG and iiyama 23inch IPS screens to that as they're incredibly well priced and really really nice.
Definitely get IPS though
