Recommend a PSU.
barbosa
Hi guys. I have two rigs and one of the PSU blow off(literately). So I'm thinking to get my 5 yrs old Enermax 850 that I use in my new rig and change to my old rig.
my specs:
2600k at 4.4ghz
570 gtx oc(maybe sli in future)
sabertooth p67
3 hard drives
1 ssd
asus d2x
6 fans.
I like the corsair ones and thinking between the hx 1050, ax 850 or be quiet! 850. what do you think?
tks in advance.
Think its a smart choice. The AX/HX is very good psu's. I got the 1200AX myself
Yeah i forgot to tell you. The AX series have 7 years warranty
a Corsair AX850 would be perfect for you,
but if you wanted some headroom for future upgrades, i would recommend the HX1000 or the AX1200
beQuiet also do a nice range of 850+ PSUs
Yep HX/AX.
If you are on a budget, then i would recommend the OCZ ZX 850W Gold. A mate of mine has this with a 2500k @ 4.7 and 2 6970s. he loves it.
