rebuild P180
name='deathwish' said:
your nasty :D
whys he got a 7900 gto if he dosnt play games?
anyway nice steal what will he do once he finds out though
hohohohoooooo, thats what brothers do innit! MWAHAHAHAHAHA!
and why hes got a 7900gto.....he used to play AoE a lot, and his onboard GFX wasnt upto the job, got a 79gto and fitted it and he was happy, but since about 9 months ago, he started to play a weird free 2D online MMORPG thingy, and that was it, no more AoE.......so its only fair i nick it and make good use of it right? MWAHAHAHAHAHAH!!!!!!
oh, look what i have here.....a nice paper weight!
name='FragTek' said:
That Commando looks beast. What's the LED readout?
the one in the back panel??
thats the bit where it tells you codes for whatever is wrong.....
its like the 2 digi number display on some boards with a 2 number code, but Asus made one in the back panel instead.
not in a great place but i guess its better than nothing.
I thought maybe it did something more fancy than just read debug codes, oh well :( Nice board none the less!
small small update, no pics tho!
hooked most of the things up and fired it up, and im happy to say everything is working fine at the moment.
till i get all the stuff i need it wont be put inside the case.....
and just as i thought my bad luck has all gone away, somehow i've manage to break my DVI cable!!!!!!
FARK!!!!!!!!!
im slooooowwwwllllyyyyyyy getting there.
did some testing today just mainly for peace of mind.....everything looks OK so far.
bits to come are:-
EK Commando Mosfet block. (waiting for it come on market)
black 10/8 hose (need to find a place that stock enough)
*i think* a few more fans
maybe within 2 weeks i might finish rebuilding it.....
