inspector-71
fatty said:Ok in the other post about this issue I have my pc set for 24/7 use x6800 420 x 10 using firmware 937 and have no issues, I have also gone into the bios and changed the fsb after a restart and still no double boot problem so maybe the firmware will work unless you are doing huge overclocking changes in the bios
firmware here http://www.extremecoolingtechnologies.com/support/downloads/FIRMWARE937GT.ZIP I have also just spent a few mins in the bios changing vcore and some mem timmings with no double boot issue
So when setting up for the first time is it adviseable to
change boot priorities
save changes + exit
disable on board sound
save changes + exit
change memory volts
save changes + exit
change memory timings
save changes + exit
change fsb
save changes + exit
would that be safe enough? If I changed them all at once would you expect the double reboot?
