SaaintJimmy
Member
Hello everyone! I'm finally back with a new project, this time on a Cooler Master SL600M with a mineral stone as theme, the Realgar.
This will be my main entry for the upcoming CMWS19, together with Sky Three!
Special thanks go to MSI, Cooler Master, Adata XPG, Alphacool and Resin Pro, for providing materials and hardware for the project!
So let's take a look at the case while I take it apart to start modding
First thing to do: find a more optimal placement for the PSU, which will be more far into the front, with this custom brackets (after having done the necessary cuts on the case panel)
Back panel is swapped with a 10mm acrylic panel which will house the 360 radiator. This aluminum profile on the sides will help squaring out the internals and will serve as covers and structure elements for the center panel
Let's leave it at this huge acrylic panel, about to be sectioned
