RayStorm D5 RX360 WaterCooling Kit
Ralm
Hi there people,
Im looking at a kit where I can start gathering money for.
It will be my first kit and I wanted something good and that will last long as well allow me to upgrade in the future, like adding a graphics card into the loop.
For now, it will be CPU only.
Do you guys think that XSPC RayStorm D5 RX360 WaterCooling kit does the job? Is it a good kit for starters?
I normaly dont have that much money, so when I invest on something I like to make the right choice right away, rather then buying something more a less to start and buying better in the future.
Waiting for opinions and sugestions,
Thanks.
This is a perfect kit for a beginner as it come with everything that you need except coolant. Personally I prefer tube res solutions as you don't need to leave as much tubing for filling the res etc. The tube solution also gives you better flow so when you do upgrade you are going to be getting better flow as gravity is feeding into the pump. Definitely go for compression fitting as they have nice aesthetics and I prefer them as they are safer for beginners =D Hope that helps and good luck.
Well, yeah, compression fittings all the way. I just dont trust leave a tube just place with normal fitting (dont remember the name) because of stuff I remember of when playing around in my farm with hoses and water lol.
Well, yeah now I just need to get 400€ loool, so expensive.
Yea it is expensive but it is well worth it and you can get pump mods that fit on EK tube res. They are the best in my opinion. Happy saving =D
Well, Im sorry about that. I saw all your reviews in youtube, just didnt remember this one.
And I normaly dont go into the website searching for everything, it just doesnt come into mind to do so.
Even so its 1 review made by 1 person. Doesnt mean that other people can think diferent or had any issue with it.
Anyway, thanks as allways,
Ralms.
