Raven RV03
| raVen |
HI thats my rig
New GPU and Monitor arrive today
My old KFA2 GTX 470 vs Asus GTX 580 Matrix Platinum.
Hope that you guys like it.And sorry that I had problems with pictures
Yeah when I'm tring to use (insert image) I get this "You are not allowed to use that image extension on this board."
So what exactly I have to do to fix it?
Even when I'm changing the last tag to [/IMG] still the same "You are not allowed to use that image extension on this board."?
Can any moderator help me with this one please
As I told you in PM you need to redo them all from the imgeshat embed links
remove them all and just click insert image and paste the link in
You can easily embed them by clicking on the link and copying the forum link on the 'embed this image' section on the right hand side.
Okay I'm confused now
Sorry Tom but I dont have the best day for thinking
Can you tell me step by step how to do it
Thanks mate.
But copy with tags or just the link?
Dude I'm not using Samsung monitor anymore, check my sign and other pictures
click embed at the side of the image
then copy the FORUM code and paste it in.......
let me know when you have got the hang of it then Ill delete this fail thread
See the IMG codes in the pic you need those at the begining and the end of your links the same as in the pic.
Sieb thats wrong on imageshat click one of his links and youll see what I mean. You are just confusing matters now
In your opening posts; either remove all the IMG tags cause you can use the magic self-embedding "Forum" URLs, or use "Direct Link" if you want to use IMG tags or this forums Insert image button.
