Random BSOD
Browsing the web you say,
That will be it then. The error ( or virus whatever ) lies there.
Have you ran Malaware bytes?
What extensions are in internet explorer?
Well I don't actually use internet explorer. I always use firefox.
I haven't run Malaware bytes, will do that now.
But the thing is, it has also happened to me while watching videos. I'm not sure if I had firefox open while doing that though.
And if I don't shut my PC down after a bsod, the bsod will occur much quicker (sometimes even when I'm not fully into Windows yet.)
Edit: So I ran a quick malwarebytes scan.
Code:
Malwarebytes' Anti-Malware 1.50.1.1100
[url]www.malwarebytes.org[/url]
Database version: 5494
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
10-1-2011 13:08:44
mbam-log-2011-01-10 (13-08-44).txt
Scan type: Quick scan
Objects scanned: 157731
Time elapsed: 3 minute(s), 48 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 6
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 1
(No malicious items detected)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServicesOnce\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServicesOnce\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\load\Recycler (Trojan.Agent) -> Value: Recycler -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
c:\Users\Arjen\AppData\Local\Temp\iexplorer.exe (Trojan.Clicker) -> Quarantined and deleted successfully.
haha that should be it then if iexplorer was infected
good luck from now on
He has
CPU Make: Intel GPU Make:
Nvidia CPU: Intel Core 2 Quad Q8200 2.33 ghz @ 3 Ghz
Motherboard: MSI P45 Platinum
Graphics Card: Asus ENGTX470 730/1460/2000
Memory: Crucial Ballistix Tracer 4GB DDR2 860Mhz CL5-5-5-15 2T
Cooling: Prolimatech Mega Shadow (w/ Scythe push/pull)
Power Supply: Corsair TX750W Sound Card: Creative X-Fi Xtreme Audio
Monitor: Samsung SyncMaster P2450H 24" 2MS Full HD
Sposedly
He has
Sposedly
Correctemundoo, although my cpu is now running at 2,8 instead of 3.
Hard drives are 2 Spinny F3's in RAID0 and a Western Digital Caviar Blue 640GB
No there haven't been any, so far so good then but there's this weird program launch popup I get at startup.
I haven't resized it so you can actually read the text.
I get that popup everytime I boot up my pc.
Looks like a virus to me mate. Have you got a boot disk that you can read/write NTFS from?
If so, I'd use it to delete that file and then remove it from any startup listings (msconfig/autoruns).
