Rampage 3 Gene
baw563
Hi all , can anyone tell me the right temps for this MB , my IOH temps are 60c idel up to 68c underload this is out of the box no clocking, is this normal??
wow that is hight , can you tell me how is that going to hold up to overclocking?? by the way great vids they are the best mate .
I thinks it would be a good to tell the world about this and may be a vid on how to change the past on the NB ??
Just the way they are. Its simple take the heatsinks off, clean the paste, replace paste with anything NON conductive, refit. done.
thanks for the fast return ill give it a go , i hope to get this setup to 4GHZ on the intel I7 930 noctua N14 air, vengeance 12GB ram 1500psu ATI 4870x2 , your vid on the vengeance Ram was first class
