U unreal New member Apr 13, 2006 #1 Hmm, Out of interest how do you guys attach your ramsinks? Some say alumina in the corners and ceramique on the majority of mem graphics, others say a mix of AS5 with alumina? Cheers Ben
T Thickbrit Guest Apr 13, 2006 #2 I use 1/3 mixed AS adhesive to 2/3 AS5,as i ripped off a couple of ram chips using 50/50,whilst trying to remove them.
B bazx New member Apr 13, 2006 #3 as thicky dose but also use ceramique and a drop of super glue each side of the sink last time which worked well too
U unreal New member Apr 13, 2006 #4 bazx said: as thicky dose but also use ceramique and a drop of super glue each side of the sink last time which worked well too Click to expand... Hmm that last method sounds good (aka I already have ceramique and super glue ) When you say last time, have you tried removing it? I dont wanna kill my precious (now old) x850...!
B bazx New member Apr 13, 2006 #5 all i put on was a drop each side worked like a charm and ya just give a littel twist to remove them
M Master_G New member Apr 14, 2006 #6 name='Thickbrit' said: I use 1/3 mixed AS adhesive to 2/3 AS5,as i ripped off a couple of ram chips using 50/50,whilst trying to remove them. Click to expand... Works well for me G
W welshtom Guest Apr 14, 2006 #7 i used thermal tape stuff off ebay. the ramsinks get hot so it must do something
