M mVp24 New member Apr 17, 2007 #1 Hey, on most C2D boards, there is a ram standard of ddr2800. Does that mean I won't be able to run DDR2667 sticks on the board? Thanks.
B Bogel New member Apr 17, 2007 #2 You can run DDR2 667 on the board, i wouldnt mix them, not sure if taht would work, but as far as i know, DDR2 800 and down should work
F FarFarAway New member Apr 17, 2007 #3 Basically all RAM will work on a board, even the high spec stuff will run at DDR800 with a little bit of timing tweaks The 667MHz set would run at 667Mhz and almost certainly higher with a bit of tweaking
J JN New member Apr 17, 2007 #4 Yeah as Bogel said, It should wok fine. You'll just need to run the ram at a divider.
Mr. Smith New member Apr 17, 2007 #6 name='Bogel' said: Call me dumb, but i still dont know what a ram divider is Click to expand... Google is your friend
