GLN
Hi guys
im in the middle of a build and i have ran into a problem. i am trying to mount a Hardware Labs Black ICE Radiator GTX-Lite 360 in the front of a corsair 780t, the problem is the 30mm screws includes are to short to go through the fan then through the case into the radiator.
ive got some ek radiator screws which are slightly longer but are a smaller tread. it does say on the hardware labs box that only there screws will fit but i cant seem to find any longer ones
does anyone know where i would be able to get the right screws from or any other ideas to get round this problem
Thanks
Thanks
