Radiator Fans plus Fan Controller
reeper250
I am wondering which fans would give the best performance/looks for an XPSC RX360 radiator in a Silverstone Raven EV02-E case.
I really would prefer LED's to add interest.
There will also be green watercooling tubing inside.
Xigmatek Crystal
http://www.specialtech.co.uk/spshop/customer/Xigmatek-Crystal-120x120x25mm-Green-LED-Case-Fan--CLF-F1253-pid-11499.html
Yate Loon D12SL
http://www.specialtech.co.uk/spshop/customer/Yate-Loon-120-x-120-x-25mm-Case-Fan-Transparent-with-Green-LEDs-1350-RPM--D12SL-124LEDG-pid-6822.html
Enermax Appolish
http://www.specialtech.co.uk/spshop/customer/Enermax-Apollish-120mm-Green-Fan--UCAP12-G-pid-9784.html
Silverstone Air Penetrator
http://www.specialtech.co.uk/spshop/customer/Silverstone-Air-Penetrator-120mm-Green-LED-Fan--AP121-GL-pid-12569.html
Or just the good old (boring) 1800RPM Scythe Gentle Typhoons?
Or even another fan, but I don't want to spend too much...
Over to fan controllers
6 Channel
Zalman AM MFC1 Plus
http://www.specialtech.co.uk/spshop/customer/Zalman-ZM-MFC1-Plus-525-6-Channel-Fan-Controller-Black--MFC1-Plus-pid-4149.html
Phobya FanMax
http://www.specialtech.co.uk/spshop/customer/Phobya-FanMax-525-6-Channel-Fan-Controller-Single-Bay-525-pid-14380.html
AeroCool F6XT
http://www.specialtech.co.uk/spshop/customer/AeroCool-F6XT-6-Channel-Fan-Controller--F6XT-pid-14637.html
Thanks!
You can't fit an XSPC RX360 in the RV02 you will need an RS. The Yate Loons and the Silverstone Air Penetrators are no good they have hardly any CFM and when put on the rad they will have less because of the resistance, the Enermax Appolish are quite good they have a good CFM and good static pressure so they will be good for radiators. Don't know about the Xigmatek Crystal though.
I don't know about fan controllers so someone else will have to help you on that.
When using a fancontroller,i would chose cm sickleflows with green leds.
I would choose neither controller,Lamptron fc2 will be my choise.It handles up to 45w a channel,giving the option to run several fans on each channel when using fansplitters.
i'd choose the lamptron aswell! i think there has been a revision so make sure you you get a new one if you do pick it up
