Fan controller help
I think they will probably work the same. The NZXT has 5 fan control. But the Aerocool has eSata, and 2 USB as well as MIC and earphones...
It will basically come down to what you want it to look like or how many fans you want to control.
The NZXT has the time.
see some reviews:
NZXT:
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=340&Itemid=58
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992004
http://www.overclock.net/t/1016299/aerocool-v12xt-vs-nzxt-sen-001lx
Aerocool:
http://www.hardwaresecrets.com/article/Aerocool-Touch-2000-Fan-Controller-Review/783
http://www.legitreviews.com/article/1029/1/
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999198
Just use resistor cables and adapters, they're so much better.
What fans do you have btw?
On the H100 i have the stock ones but will be getting new ones soon, i want a controller as well because i want to fully turn off some case fans when im not suing the computer
