hi, i want to put a water cooling loop in my system for cpu only i currently have an corsair H70 which i dont think is bad i just want cooler lol now as a kind o direct replacement for the H70 i was thinking of this rad http://www.hwlabs.com/index.php?option=com_content&view=article&id=12&Itemid=9  as i want to keep cost down by not buying anything extra like fans or having to change to much inside the case, now the other rad is a 280mm rad for the roof of my corsair 650d and is the only 1 compatible as far as depth is concerned and this rad has the 20mm fan spacings required to fit inside the 650d for a 280mm rad http://www.hwlabs.com/index.php?option=com_content&view=article&id=29&Itemid=26  the rad is thinner than i would want but the only 1 that will fit in my rig i have checked the mesurements and a 50mm rad would fit but i cant find 1 with 20mm fan spacings, so my question to you awesome guys is which would i be better to go for performance the 120mm rad would be push pull and the 280 would be push only , the reason its a 280 is i already have 2 140mm fans in the roof so yeah thanks guys any help appreciated
