Xrqute
Hi Guys,
Well i soon plan on changing out my current fans as I'm changing the color scheme of my build and well I'm not happy with the build quality of my current ones.
originally i had my heart set on these, But my current fans are rated at 69.69CFM and 2.94mmH2O @19dBA and the Corsair's are 57.24CFM and 1.46mmH2O @26.4 dBa which to me seems like a huge drop especially on the pressure side so I've been looking around at different fans trying to see whats out and about and well I've found-
Aerocool DS Fan 120mm White LED Fan- 54.8CFM and 1.48mmH2O @15.8dBA: I like these because they look amazing and are super quiet yet providing almost identicle performance to the SP120 Led's
BitFenix Spectre Pro 120mm White Tinted Blue LED Fan- 56.22CFM and 1.24mmH2O @18.9dBA: Once again very similar performance but falls inline perfectly with my color scheme.
BitFenix Spectre Pro White 120mm PWM Fan- 70.52CFm and 2.6mmH2O @26.1 dBA: much better performance then the last but also much louder but at least with the added benifit of PWM so i can slow them down when the rig is under load.
Corsair Air Series SP120 Performance Edition Case Fan- 62.74CFM and 3.1mmH2O @35dBA: amazing performance but bloody loud.
Corsair Air Series SP120 Quiet Edition Case Fan- 37.85CFM and 1.29mmH2O @23dBA: much less noise and much less performance.
Noctua NF-F12 Industrial PPC 120mm 3000RPM PWM Fan 186.7 m3/hr (109.89 CFM) and 7.63mmH2O @43.5dBA: Obviously mind boggling performance with a dBA to match, PWM so i can turn them down to a low RPM. as low at 750Rpm.
Noctua NF-F12 Industrial PPC 120mm 2000RPM PWM Fan- 121.8 m3/hr (71.69 CFM) and 3.94mmH2O @29.7dBA: great performance but still a little loud but once again PWM.
Noctua NF-F12 PWM 120mm Fan- 93.4m3/hr (54.97CFM) and 2.61mmH2O @22.4dBA: great stats all round decent flow good pressure and a decent dBA.
Noctua NF-S12B Redux 120mm 1200RPM PWM Fan- 100.6m3/hr (59.21CFM) and 1.31mmH2O @18.1dBA: once again very similar stats to the SP120 Led's
Out of those fans list what would you choose and why?
I personally like the look of Noctua NF-F12 PWM 120mm Fan and Noctua NF-F12 Industrial PPC 120mm 3000RPM PWM Fan (using the PWM feature to wined the RPM right down but have all that extra in reserve for those hot Aussie days) but in saying that at $29 and $32 Aus respectively i can get Corsair Air Series SP120 Blue LED Fan Twin Pack for the same price/less.
What CFM and mmH20 should i realistically be aiming for? Keep in mind i am using XSPC AX240 and AX360 Rad's in Push Pull.
there just doesn't seem to be anything to match my Cooloermasters CFM:mmH2O:dBA. To bad they arnt of better build quality.
