Tolemac
Active member
Hi guy's me again for advice
I recently bought a Sapphire R9290x Vapor x what I would like to know is if its worth including in my loop and would I need to add another 120mm rad to the loop atm the vaporx idles ar 38 degrees celcius and never goes over 70 degrees c under load my cpu idles at 23 degrees celcius and doesn't go over 35C under load
I dont want to waste money on a block if its not really going to benefit me that much
Thanks in advance
Thanks in advance
