Question for the modders, MB stand offs
Rob_the_scot
I'm mounting a itx system to a wood the problem I have is what common size are the threads of motherboard stand offs?
is it m3?
I was going to buy M3 X 6mm steel screw inserts to hold the mobo stand offs
http://www.ebay.co.uk/itm/271148455368
This is the only part im stuck on every thing else has been a breeze
P.s sorry if this is in the wrong section
There are loads of M3 x M3 available on places like RS, 6-32 UNC x M3 is quite common for the application, maplins have some too i'm sure you'll find something suitable for the insert very easily.
I try to avoid using standoffs in custom stuff and just mate the motherboard directly, lots of options beside the obvious when you don't have to conform to ATX spec.
JR
