Question for NZXT S340 Owners
pyschometal
Can anyone confirm that I can fit a H110i GT in the front of the NZXT S340 without taking out the cable vanity cover or any obstructions/ touching the case roof or PSU shroud?
Anyone have knowledge regarding what the airflow is like compared to the H440?
I have the H440 now and it is a hot box when gaming at 4K, I know that I can get the NOCTIS 450 but I would prefer a much smaller case. I just don't want to have the same airflow issues I have now.
I have tried the Corsair 400c, there were too many issues so looking for alternatives and as I mentioned, I like the smaller sized cases.
Thanks.
Thanks.
Hi @pyschometal
I own this case and have the H115i installed. As long as you have the fans in front of the rad your all good to go. As air flow goes compared to the 440 I cant answer that im afraid.
I would recommend pcpartpicker if you change your mind, the system build section is great for flagging up most build incompatibilities.
Cheers
Lee:)
If you say the 440 is a hot box the limited roof cooling wont help you on the 340
Best thing you can do is get some decent fans in the front of the 440 and have your Hydro cooler in the roof.
