T.R.A.N.C.E.
So doing the build below currently and wondering if I should have the fans on the rads exhausting into the case, or out of the case, or front rad exhausting into case and top rad exhausting out? I personally am leaning towards both rads exhausting out of the case, but then will there be a problem with limited air intake from within the case then?
Cheers
The water side:
Rad 1: 420mm Coolgate in Push Pull mount in Roof
Rad 2: 280mm Coolgate in Push Pull mount in Front
Fans: 11x Arctic Cooling F14
CPU: EK Supremacy Nickel/ Clear
GPU: EK-FC R9-290x Nickel/ Clear
Pump: D5 vario (Swiftech MCP665)
Reservoir: XSPC Acrylic D5 standing Res
Tubing: Primochill 1/2" ID 3/4" OD Clear
Fittings: Mix of Alphacool and XSPC compression
The hardware side:
Case: Fractal Design Midi R2 (mod to fit 420mm rad in roof)
PSU: Seasonic X-1050W upside down mount (mod to use 140mm Arctic fan)
Mobo: Asus Z87 Gryphon
CPU: Intel i7-4770k
GPU: Gigabyte R9 290X 4gb
RAM: 8gb Team Xtreem 2133mhz C10
SSD: Plextor M5S 256gb
Cheers
The water side:
The hardware side:
CPU: Intel i7-4770k
