tolagarf
Member
I'm having issues properly controlling my fans on this board, and looking for options to PWM control the fans using software.
The BIOS doesn't offer good options to control the fans, since this board does not have QFAN support. The only options are something like this: High speed, Full speed, Generic speed, Manual. Setting it to manual I can adjust the duty cycle, but there is no way to set up a fan curve and ASUS AI Suite does *not* work with this motherboard, I already tried.
So that only leaves me to use SpeedFan, which supposedly supports this motherboard in the latest version, however no matter what I do, I cannot get this software to work.
As you can see in the screenshot below, there's a lot of these "DO NOT USE" options. To get SpeedFan to work, there should be an option named "Software controlled". But honestly I've tried this software before with other Asus boards and have never gotten it to work and I really need help with this, or some other way of controlling the fan curve.
