(C&P from another forum)
Right... its time for me to start a project which will be my last due to wasting too much money
This rig will be based purely for gaming with the occasional web surfing and university work.
Unforunately i don't have all the components i need but thats only the third watercooling loop.
Specs are below: (reason doing this early - so no-one nicks my ideas/name
*LONG LIST*
A64 4400x2
DFI SLi DR Expert Mobo
2x1Gb HZ4000 Gskill Ram
BFG 7800GT OC (sold, getting X1900series from HK
2x250Gb Samsung Spinpoint SATA2 HDD
Seasonic S12 600w PSU
Sony DVDRW
Mattrix Orbital MX212
6 UV Cathodes
MountainMods Opti1203 Model in Black
BFG Ageia PPU
Loop 1 (CPU):
Swiftech Storm G4, Laing D5 Pump, Thermochill HE120.3mm Radiator, Innovatek Fass o'Matic reservoir including bay, 7/16" Muskaleer Tubing, 3xAkasa LED Green 120mm Fans, UV Dark Blue Dye.
Loop 2 (GPU):
EK GPU Block, Swiftech MCW60, Laing D5 Pump, Thermochill PA160.1mm Radiator, Tank o'Matic Reservoir, 7/16" Muskaleer Tubing, 1xPanaflo M 120mm Fan, UV Green Dye.
Loop 3 (Pheripherals) Aqua Computer:
Thermochill HE120.1mm Radiator with 8mm Quick Connectors, Aquaero VDF Display, Aquastream+Control Unit, Innovatek Flow Sensor, Water temp sensor, 2xAquaDrive Harddrive Cooler, Aqua Tube, Aquabay, Aqua Jet, 2xRamplex coolers, Twinplex Chipset cooler, 12ft 8mm Aquacomputer hosing, 1xPapst LL 120mm Fan, UV Red/Orange Dye.
*LONG LIST*
A64 4400x2
Sony DVDRW
6 UV Cathodes
BFG Ageia PPU
Loop 1 (CPU):
Loop 2 (GPU):
