Im sure this has beeen covered numerous times but i cant find it so apologies for repeating questions...
For reference, current plan is a Monsta 240 for the CPU loop (Koolance 370 block), and a Monsta 360 for 2 6970s (2 x XSPC 6970 block)
I am happy to listen to advice re this either of these being shitty blocks.
What, if any, are the options for a very quiet, high flow, good head, dual bay / dual loop res/pump combo ?
Are the various non drive bay pump/rad combos generally accepted as being quieter ?
All things being equal, I would rather go with a double drive bay double reservoir or two reservoirs with pumps attached just to keep the pipework neat.
Thanks for your patience.
