Hi all
when i was gaming suddenly my pc turn off and power led was blinking on/off ...then after shutting down manually after few minutes is worked again but then i got an error message from the MB that was a power surge protection beacuse the psu was instable.....
after a few times i reset the bios see if that helps now sistem is stable but
i check my watt usage under load and now is above 1000 watt .. before was around 600 no wonder after 20 min is shut down
i running 2x 780 and a 4770k with a corsair ax860i ....i think is on is foot and it tries to compensate ...or could be something else ?? oh and one more thing is running on stock .
thanks
thanks
