name='badboy200' said:Bort sleeving kit and new connecters for my psu. UV blue to match most of what is inside my machine. Removed connector and sleeved wire Replaced all the new connectors put power supply back. Plugged every thing in and now it wont work. Mobo light on. Trys to boot then speaker gives me continuos beeps. Some thing gone wrong any ideas???? Hoping hasn't damaged and components. Apart from psu which i am replacing with hyper type r 580.
name='SuB' said:surely it matter which way u put the grounds in since they are seperate rails?
name='bloodthirst' said:dont get those hyper psu, ive heard of so much trouble with them. there just pretty. but they suck performance wise your better off getting soemthing like a tagan
My wordy yes!!!name='FragTek' said:A ground is a ground...
badboy200 said:So for my Next Question. Best water cooler. Zalman, Water chill, or cooler master?? Any help would be grateful.
name='PV5150' said:Yeah listen to and chat with Fraggles or XMS mate, they're very experienced in H2O setups. IMHO custom setups are the way to go, the kit versions usually have some major downfall associated with them...sucky pumps and restrictive tubing sizes being the major ones![]()
