I am moving all my wc to an external cabinet holding 4x 350 passive reservoirs. There will be 4x 80mm Silenx pulling cold air in and 2x 120 mm pushing out. I want to use a separate psu to power the fans. If they are the only load on the psu, will the psu run? I will be bridging the green switch wire to ground - do I need to do anything else? *Edit Also, If I want to use the main pc to switch on the remote psu, can I just connect green to green and black to black?
