T
Thickbrit
Guest
Heres a few quick pointers on how i fitted my gt on the dfi875p-t.
1: Widen the 2 outside edges of the 2 outer slots on the thinner end of an xp mounting plate by about 1mm each side.You can also use a p4 plate,but i felt it put too much pulling pressure on the overall assembly once bolted up.
Be sure to alter the thinner end.
2: Centralise the rear heater plate between the 4 h/s mounting holes and stick to mobo with sealstring seal.
