Projector?
Futures Truth
Would projecting and image of a computer game on a wall be a good or bad idea? I'm thinking of doing this, not exactly sure if its too bad.
With the right projector it can be an awesome experience... Setite has his room setup with a projector for gaming and AFAIK he loves it. Need a high quality projector that supports a decent res however.
Would a projector be able to keep up a decent enough refresh rate to make the high fps worth it?
...If that makes sence.
I used to play CS1.6 with a Viewsonic projector that only cost about $700 and it was awesome! I think I still have the vids of it posted around in the Off Topic forum somewhere.
I used my dads work projector once or twice.. and I have to say WOW!
Even though the res is smaller than my screen, it sure looked stunning.
And it does make you feel like you are there, becasue it seems a WHOLE wall is moving infront of you! :D
If it was on one of my walls and you didn't ask for your projector back, then it would be a brilliant idea!
It would work well on any wall.
Much better to pack away a screen then have a big plasma/LCD jobbie always dominating a room.
