Project [WS] White Snow ITX Build
Werxx
Hi All.
This is my second Project build thread, i have another one ongoing which is for one of my clients. This machine is for my own personal use. This ITX build will be used as a HTPC & Gaming rig.
The reason ive gone for ITX is primarily down to the lack of space for a full size rig and setup.
I started the trial fitting the components i had today so i can make some provisions for the water cooling loop.
The case really is excellent, loads of free space for the cooling setup to be routed throughout the case and enough space to house a fair spec/sized graphics card.
Specification;
Case:
Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window - White
Motherboard:
Asus Maximus VIII Impact Intel Z170 (Socket 1151) DDR4 Mini ITX Motherboard
Processor:
Intel i5 / i7 (Still to be finalized)
RAM:
Corsair Vengeance Dual Channel 16/32GB (Still to be finalized)
Power Supply:
SuperFlower Leadex Platinum 550W Fully Modular White
Water Cooling:
Custom hard-line loop first layout design as below.
240mm Roof Mounted Rad - Slimline
CPU Block
GFX Block
Pump
Reservoir
Graphics Card:
Monitors:
HTPC Sony Bravia 55" LED
Gaming rig Samsung 24" LED
