Project: Paint your R.O.G
Goofy
Hi,I apologize in advance for my english,I am here to present my new project that will see me in the company of dremel and paint cans and friend 600T:lol:, which has suffered a "major surgery", then i will explain why :)... the project will include a total painting of the case(in fact the project is called "Paint your ROG";)) and in the processing of a sheet of plexiglass to create a vertical support of the hard disk (to hell those awful cages 5.25^_^) will follow later the assembly of a complete liquid cooling system that involves the use of:
2 radiators (front 240mm and thickness of 80 mm, higher by 360mm and 30mm thick)
Kit Pump / Res Bitspower
EK Asus Maximus V Formula Liquid Cooling (Mosfet and Chipset)
Nickel EK Supremacy
EK GeForce GTX 670 Nickel CSQ (SLI)
EK GeForce GTX 670 Backplate (SLI)
Bitspower Fittings / Monsoon (I really need these many)
Tubes Masterkleer 13/10
Mayhems Pastel red (red of course);)
let's start with some image!
here are the first photo, note the cuts made in the front and top for housing the radiators and elimination of the cage 5:25:eek:
Nice cuts, are you going to put some u ring rubber on the cuts to clean it up? You know like TTL did on Orca? It just makes it a little cleaner hides any nasty bits.
A little something like this...
Look forward to seeing more
looks interesting will follow this one.....again :)
I don't really know why you deleted your previous post but if you did to add the pictures, you could've used the edit button in the bottom right corner of your post.
@maniac thanks, I deleted the previous post because it gave me error "Invalid Thread specified. If you followed a valid link, please notify the administrator" :lol:
update/
@BradleyW-H Thanks for the information
P.S. how did you upload the picture so big with the inscription "This image has been resized. Click this bar to view the full image."???
sorry but I'm new in the community
Upload your pic to imgur/photobucket, copy the link, in the reply box click on this img
and paste the link.
Goofy there is a rule in this forum for no double posting. ie two posts after each other. if you posted and and no one replied and you wish to add something, just use the edit button in the bottom right corner.
The admins hate it and it gives them extra work hehe :)
Because you dont have enough posts / been a member very long our spam filter pics up links/images and send the thread or post for moderator approval.
So every time you post a pic or edit the thread this will happen till you stop being an idiot and deleting threads and starting them again.
Just chill out and be patient.
sorry I did not know:notworthy:
I knew what case that was immediately after opening this thread considering i have been staring at and cutting away at mine for 3 months i would hope so. looks good so far check mine out if ya like to see the odd direction i went with it.
Gift from HighFlow:D
Bitspower Top Acrylic
Bitspower Mod Kit
Alphacool Pump VPP655
Bitspower Dual/Single D5 Top Upgrade Kit 150
Crimping pin Molex
Here is the result:eek:
always nice to see another custom loop build
are you going to sleeve that pump cable?
for the moment I will use only extension:)...
The project go on!
PSU with Carbon sticker
SSD mounted
The rad and reservoir are ready:D
