DeMoB
As an effort to move my friends from console gaming to PC gaming, I've offered to build a PC for one of them based on my 'spare parts' and a few purchases to get the most from the system.
It's going to be as much hardware as I can fit in the very modest budget, which translates to building it around an LGA775 platform (mostly because I already had the motherboard and RAM available).
So I present to you.... Project Overdrive
The case I'll be using for this build is a Silverstone SG01. It originally had a Pentium D system in it, so has been around just a little bit longer than the hardware I'm about to put in it.
Stripping it down brings us to the inside. There was a HDD rack at the front I forgot to photograph that had an intake fan on the side too. The case fits a mATX board and full sized PSU, so there are plenty of options for expandability.
However, I'm not happy with the CPU clearance the PSU location provides (above the motherboard/CPU). You're pretty much limited to having the stock CPU cooler, so something will have to be done about that...
A few rivets later and were down to the bare chassis.
I figure there's enough room at the front of the case to mount the PSU, and I can work out where to put the displaced hardware as I go. >_<
First up is to trim the dual bay ODD cage to fit above where the PSU will be mounted:
Then I need a way to secure the PSU in place in its new home. Using some offcuts from before, I can make a bracket that the PSU can screw into.
By chance, I found that I could fit the HDD sideways in the ODD cage. It's a perfect fit, so I cut out a bracket from the original HDD cage to hold it in place there:
And then all that riveted back into the case:
Made a slight mis-calculation with not leaving a gap to plug the HDD SATA cables in, but back to the dremel and a couple of quick cuts later:
I'm ready to start putting hardware in this now, but I've still got a few things I want to finish up first, so I'm going to have to leave you hanging a bit before I do the big reveal. So stay tuned!
