Processor upgrade? (775 - Q6600)
AvengerUK
Hey all,
Im considering a processor upgrade - as my current really cant overclock (isnt stable/gets too hot etc etc) - party this is due to my motherboard (except when it comes to heat!) - so im considering getting something different - however im not sure 1) what i can get (what my motherboard supports) and 2) if theres much point in changing?
Q6600's are supposed to be good overclockers (Eg. Nick R's sig), some people have got them to 4GHz. Like Nick said, what revision is it?
I have tbh here. If the cpu is a "G0" revision, I don`t think I`d upgrade inside the 775 socket (not unless I have money burning a hole in my pocket - even then tho I`d look to buy something else, like a newer mobo).
If it isn`t a G0, efficiency and heat-wize, selling the sucker for even a G0 or going 9450 if the mobo likes it. Don`t even know if these 9450s clock as good as the Q6600.
Basically the Q6600 is a tremendous cpu. Upgrading it is a tricky decision for me. Think they`d have to eol it to stop me recommending it.
As Rast said, the Q6600 is a fantastic chip.
THE best overclocker I have ever encountered, got mine running at a constant 4Ghz. Loving it.
Wait for the new socket before upgrading the Q6600 can not be beaten. ;)
as everyone else asked, what stepping/revision is your current Q6600?
if it is a G0, the bad clocking experience could be due to the nvidia 650 chipset on the motherboard *shrug*
i know my 680i isn't great with my quad.
the quad is in a drawer atm, i swapped it out for an e8500
If you have an Nvidia 6 series chipset then I would recommend upgrading the motherboard rather than the CPU.
yep, good advice ;)
this nvidia chipset kinda sucks, expecting a new p5q3 deluxe in the next couple of days :)
name='Pyr0' said:
yep, good advice ;)
Oooo, very nice!
Never been a huge fan of Intel.. because of the lack of SLI. But since the Maximus I am in love.
I have heard goodish things about the new Nvidia chips mind you.
Yeh ive heard the 6 Series chipsets arnt that good at overclocking.
The revision is not "G0" - its a "B3"
Problem is if i was to get a new motherboard for overclocking, id also need to replace my vista (OEM)
EDIT: I have overclocked before, but because of the MB/The chipset, it needs alot of extra NB juice to be stable, and this obviously creates alot of heat with the passive cooling. Would there be any point / is it possible etc to get some sort of cooler for the NB? That would just about solve the problem i think!
