Ok build the pc , connected everyting etc .....
First powerup , got into bios , tried to change some settings but the pc froze (within the bios).
Finally got in the bios to change the raid settings so my hds would be recognized.
Installed windows without a problem.
Flashed the bios from the mobo , pc freezed but after the bios was flashed , luckily.
Rebooted , got in to windows flashed the proms firmware, again the pc froze.
Connected the proms usb cable in another pc and flashed the firmware that way.
Now i can get into the bios and change settings without freezing the pc (well most of the time).
But know the pc freezes while installing windows.Tried to install windows several times but the pc freezes on different points during install (but never get to finish the install).
So the prob now is how to get windows installed (after numerous reboots sometimes it doesnt even pass post, but thats sometimes now)
Pc specs :
Asus A8n32sli deluxe
X2 4800+
2gb Ocz pc4000EB
Enermax noisetaker 600W
Xfi fatal1ty
Asus 7800Gt (for now ,have a watercooled X1900xtx ready to insert if everything else is stable)
Prom Mach II GT (doh)
I've run out of ideas for now , help .............
Pc specs :
X2 4800+
2gb Ocz pc4000EB
Xfi fatal1ty
