Big WigglyStyle
For some reason Prime95 won't push my cpu past x43 on the multi with base clock of 99.8mhz. I set the multi in bios to x45 and vcore to 1.310v for some reason the multi tends to sit around x40 and sometimes jumps up to x43 then back to x40 again. I've tried running small FFTs Large FFT and Blend and none pushed past x43 but even when it went up there is went down to x40 again.
So I guess my question is what am I doing to not let it go past x43 and is it prime or did I forget something in bios.
Bios settings I didn't change much all I did was set
multiplier to manual - 45
Load line I left at auto the options were level 1-5 or auto, auto said level 5 so I left it alone.
Vcore - 1.310v but in CPU-Z it doesn't go past 1.240v'
Also when I open an application it jumps to 4.5 1.312v but oddly it stays at 1.312 even when going back down to the x16?
Just tried a quick launch of BF3 multi goes to x45 but voltage sits at 1.256v
