PPD difference beteween a GTX560Ti and a non Ti ?!
SnW
Need a fast answer as they only have one left
can't find any info at the moment (searching of course),
or explain what the difference is between a Ti and a non Ti ??
Thanks in advance..........
The gtx 560Ti has 384 cores where as the gtx560 has 336.
A 560 (non ti) can easily get 14000 - 15000 PPD at stock and over 17000 PPD overclocked.
Found info,
thanks for the fast reply
BTW you still have the old PPD numbers in the head , its got downgraded (PPD)
what was 15xxxPPD now is 12xxxPPD
I assume this is too late.
A none Ti is about 1000 to 1500 PPD less than a Ti. Not all that much slower really.
They are kinda yellow but look like their orange indeed
i'll have to stop the FAH to check what brand it is , tomorrow i will install the GPU then i will check......
Well i can't say, i am jumping around... because of the PPD
Uploaded with ImageShack.us
That's what my overclocked GTX280 can do + 1000PPD
EDIT this is all on a dirty install including drivers,
i hope that will solve some things.....
if there is any to solve......
EDIT2 on the other hand i don't understand why my Ti's get 13xxx because that's what they first did overclocked
LOL i am glad some issues are here , wouldn't be Folding without it
Lovely Folding Ray..........
That is the exact problem I had running a 460 along side a 560 Ti.
You might find swaping PCI slots helps. For me however there was no fix.
Aaa thanks buddy, i didn't know this issue was known , helps me a lot.. now i don't have to worry that much,
rig2 is on its way
Greetings Ray....
rig2 is on its way
Greetings Ray....
The only solution for me was to find a new home for the 460. It was assumed that a 560 should work fine along side a 560 Ti.... but maybe thats not the case.
Ray it looks like your GTX280 is folding a GPU3 WU. Gtx 260's and up suck on GPU3 WU's. Use GPU2 client for that card and it should run core 11 WU's also add "-forcegpu nvidia_g80" to the command line. My 260 and 275 run around 9.2 to 9.4K PPD on the old 353 and 787 point WU's
Guys on the screenshot it IS the GTX560 that IS folding already !
my GTX280 is waiting for its second home or it will be the GTX560 non Ti...
But i wake up and I see both my GTX560Ti's doing 14xxx
tomorrow 15xxx
I love this
