D Dalyyyyy New member Jan 1, 2011 #1 Hello guys, I was just wondering would it be possible to overclock an AMD Phenom II X6 1055T 2.80 GHz, 9MB Cache, Socket AM3, 125W, 45 nm to reasonable speed?
tinytomlogan The Guvnor Staff member Jan 1, 2011 #2 really depends on all the other parts aswell dude.
D Dalyyyyy New member Jan 1, 2011 #3 ii will prob buy this motherboard http://www.amazon.co.uk/ASRock-880G...1_fkmr0_3?ie=UTF8&qid=1293812027&sr=8-3-fkmr0 and mushkin ram ?
S Squirrel-666 New member Jan 2, 2011 #5 why dont you go for one of the AM3 asus crosshair boards there good clockers.
S Stryker64 New member Jan 3, 2011 #6 Squirrel-666 said: why dont you go for one of the AM3 asus crosshair boards there good clockers. Click to expand... He's going for a cheap motherboard so I assume he doesn't want to spend the money.
S Squirrel-666 New member Jan 3, 2011 #7 ooo good point well they are good boards if you can stretch if not then i dont really know any good clocking cheaper boards.
S Stryker64 New member Jan 4, 2011 #10 MSI Fuzion I can easily get 3.8GHz out of my 1055T, haven't bothered to max it out though due to my laziness.
E Edgeyforsure New member Mar 4, 2011 #11 tried looking at the Gigabyte GA-890GPA-UD3H? suppost to be a great overclocker and its about 100 pounds same as the MSI
