BCMods
So this is going to be my personal gaming rig that i'll be building over the next couple of months. I'm going to start off by only watercooling the GPU with a 240mm rad, then moving on to adding a CPU waterblock and 360mm rad
Here are the specs that i THINK it should have
Intel i5 760
MSI P55 GD80
ASUS DCII Geforce GTX 580
8GB Corsair Vengeance @ 1600MHz
60GB OCZ Vertex 2 (boot drive)
1TB Western Digital Caviar Green WD10EARS
OCZ ZS 750w PSU
NZXT Switch 810
Watercooling hardware:
XSPC Raystorm - One of the best CPU waterblocks out there, and doesn't cost a fortune
EK Acetal/Nickel GTX 580 waterblock - Looks really nice and is a full cover WB
Alphacool 5.25" Repack Single Bayres : Clear
18w Laing DDC Pump with DIYINHK PCB
Alphacool Laing DDC Plexi Pump Top
XSPC RX360 360mm Triple Radiator
XSPC RX240 240mm Dual Radiator
2m Clearflex 60 1/2" ID - 3/4" OD Tubing - Good, thick tubing, doesn't cloud
5x 120mm Corsair SP120 2350 RPM Fan
Mayhems Aurora Extinction Green Concentrate - Need i say why i'm using this?
Deionized Water
Various Compression Fittings
Other parts:
Black sleeved cables (8 Pin CPU, 24 Pin Motherboard, 2x 8 Pin PCIE)
2x 60cm Purple LED Strips
Lamptron FC2 5.25" Bay Fan Controller
If you think i've missed anything then be sure to tell me
Cable management isn't the best at the moment, since i'm going to be replacing the motherboard this week, as well as installing the sleeved cables i mentioned earlier.
Anyway, to get things started, here's a photo of the rig at this moment in time
Intel i5 760
MSI P55 GD80
OCZ ZS 750w PSU
NZXT Switch 810
Deionized Water
Other parts:
