ok in a few weeks i will be building a new rig and i would like to water cool it however i want to do the following
1 have a single loop
2 cool 3 components 2 88gtx and a q6600
3 get lowest temps possible without having to insulate
now the loop would obviosly branch off to hit each component seperatly i'll be using a thermaltake mozart tx so space isnt a problem my question it shud i use rads or a boreas 12 cost isnt a major issue although does play a role in what i use, also what are these (circled in red) and should i put heat sinks on them?
thanks for the help
thanks for the help
