FarFarAway
Pioneer have lanched their first Blu-Ray internal drive.
The drive is EIDE + molex for the minute, but it is expected that eventually the drives will be S-ATA.
This supports both Blu-Ray and DVD:
So the end for CD-ROMs? I don't think so yet but certaintly game manufactorers are already starting to use DVD's as standard format so I would expect CD's eventually to be phased out (at least for PC use)
Info on burning Blu-Ray:
So looks pretty good as far as I can see
Prices are set to start around £200 per unit at first, but most likely go sky-diving down as production scales up. Expected figures after a year or so are at around £30ish: same as DVD today.
No word on the price of the discs at the moment, but I would expect the same trend: expensive at first, then going down in price
Read all about it here
name='Bit-Tech"' said:. The BRD-101A will read and write Blu-ray media at 2x and burn the various DVD formats at 6x to 8x speed. However, what this drive won't do is read or write regular CD-ROM media. This seems a strange choice, but if it wasn't possible to support all three major media formats, supporting Blu-ray plus DVD makes far more sense than Blu-ray plus CD-ROM.
Bit-Tech said:Blu-ray Disc v1.0 specification dictates that 1x mode will require a 36.5Mbps data transfer rate or approx 4.5MB/sec. At this speed, it would take 90 minutes to burn a full 25GB.
The specification for 2x mode doubles this data rate to over 70Mbps, halving the burn time to 45 minutes. As the format matures, burners are expected to reach 8x speed or more, writing the full 25GB in well under 15 minutes. To achieve this, drives will be nudging 300Mbps or over 35 megabytes per second sustained transfer rate. For reference, a 16x DVD burner reaches 22MB/sec.
By then, we will see Dual Layer media, just as we have for DVD media, which will double disc capacity to 50GB, and the Blu-ray specification allows for several more layers, yielding 100GB per disc or more.
