Pinnacle 24
Thanks guys:) I'm actually thinking about changing out my sharkoon fans to enermax cluster ones. Just too get some more light. I'm also thinking about changing one loop to black tubing...
Really nice job there, I think the white and black contrast would look really good. Love the sleeving...labour of love but worth it.
Thanks man:) That sleev job took me foreeever, but like you said, it's well worth it:D
love the white tubing, looks sick. Those BP fittings look the tits aswell. Love the white sleeving, I did my psu in black braid it looks good but you need the case lit up so much to see my hard work. Using white braid makes it standout more and exaggerates the work that has been done. Well done, you should be proud. :)
Have a quick question, what white braid did you use? Also did you white shrink wrap the cables underneath the white braid?
Thanks
name='cl0ck_ed' said:
love the white tubing, looks sick. Those BP fittings look the tits aswell. Lovew the white sleeving aswell, I did pmy psu in black braid it looks good but you need the case lit up so much to see my hard work. Using whire braid makes it standout more and exaggerates the work that has been done. Well done, you should be proud. :)
Thanks man, really appreciate it:) I used MDPC sleeving and I used white electrical tape on each cable. Alot of work but well worth it;)
Ordered a few things last night. 8x Enermax Cluster fans, to replace my sharkoons. Some black tubing, think I'll have the gpu + chipset loop in black. Also ordered Mips RAM cooler nickel to go in my cpu loop. And a Therrmochill PA 120.3 to replace my 120.2:D
That sounds wicked! I think the contrast between the black tubing and the white braid will complement each other. Very nice. I'm looking at white 1/2'" tubing with BP matt black fittings. Whats your reason for changing to black hose?
I think that there's a little too much white as it is now. So changing one loop to black tubing and keep the other one in white will do the trick I hope:P I will upload some pictures when I get the stuff. Shipping was 14 days for the Mips RAM Cooler:(
Very nice! Seems you have a lot of money lol
Hey cl0ck_ed: Do you got a buildlog or gallery for your build? Can't find it if you do...
No I don't. My pc is in my sig and i have a cm cosmos with wc:d-tek fuzion, laing ddc, thermochill pa120.3,120.1 etc. The tubing is masterkleer and it had gone cloudy so thinking of getting new tubing and BP fittings. The cosmos case is crap for cooling, similar problem to the corsair obsidian where the front has no intake just the bottom lol. Picture of my case along time ago http://forum.overclock3d.net/showthread.php?24282-Watercooling-Results! . Looks tidy now though.
Ok, be sure to upload some pictures with the new tubing and fittings;)
Lol, it won't be any time soon. Thinking of SSD first, x25-m 80gb hopefully. I'm also in the process of finding a job to start my career, graduated in the summer 09 and there are so few jobs for Civil Engineer graduates :( .
Also have you a validation link to your i7 d0 overclock? 4.2 is nice what voltage did you use?
Load temps are ~60 and idle temps ~35 I'm happy with those temps. It's gonna be interesting to see what adding the ram and changing out the rad to a 120.3 is gonna do to the temps...
