jongamboa93
Hello, I am finally stepping into the world of water cooling. I was wondering if a Phobya extreme 200mm rad would be adequate for two gtx580's 3g version. I am trying to fit the cards and the 200m rad into a white corsair 600t case with two bitfenix 200mm fans in a push pull configuration. Using the Koolance duel bay duel pump config, this high amount of water pressure going through these cards hopefully will dissipate the right amount of heat to achieve a good stable overclock. Any help would be very appreciative.
