Phenom II X6 only showing 5 cores
System specs:
- Phenom II X6 1090t @ stock
- Windows 7 Pro 64-bit
- Asus crosshair formulae iv (890fx & sb 850)
- Samsung 450gb 7200 rpm sata II hdd
- 4Gb single channel corsair ddr3 1333mhz ram
- Radeon hd 5770 @ stock
- 750w ocz fatality
- nzxt hades
i have flashed the bios despite it already having the latest version (1102) already on. i have checked windows, amd overdrive, and asus pc probe ii and all are only showing five cores (core0,1,2,3,4) and the whole system is pretty recently purchased (ebuyer & amazon) except the hdd which is still full of life. any ideas why i have a pentacore and not hexacore? :S
It's okay guys, after three days a patch has downloaded and is seeing all six. But might be worth remembering this if you know someone else who has this issue with their system
I was woken up by the neighbors screaming children blundering down the stairs, switched on the rig, then 'Installing AMD Phenom II X6 1090t Driver'. I had already installed the latest driver though so that makes no sense! Oh well, it's working now
was it from a new build?
meaning did u install windows after u put the hexcore in?
I'd had it sat on my shelf in the box a couple months (the cpu) while i bought the other parts but this was the first time has ever been used. I built the rig, then my bro went through bios etc and put windows on for me (i was paranoid i'd screw something up). I did have 32-bit professional on the drive prior to 64-bit, but he wiped the drive before he installed anything new (inc new 64-bit OS).
Hope that made sense
i would re-install windows or look in device manager and see if u see 6 cores
Nah it's cool, is recognising all six now that the driver patch has installed. i did kinda say already. thought tho atleast if other oc3d members have this problem with their x6 chip then they'll know to wait out a driver update (i have no idea where it is on amd's website, windows did it for me).
i have a M4A87TD/USB3 and was doing the same so i went into bios and 1 core was set to OFF. So i turned it on, Done.
