Edgeyforsure
sooo, i recently bought a phenom Ii X6 1055T 95W version pretty much as soon as i got it to post
i hit the FSB to 272x14 which = 3.8ghz and bumped the CPU volts to 1.4v
needless to say, it is stable, havent tried knocking the volts down yet, temps seem stupidly low, [20 - 23c idle] with around 34 load and 36 in games (GFX card dumps heat into the case) [ temps according to HW monitor]
im using a H50 with push/pull cooling swif2 PWM 120mm's
where should i go next? the northbridge is stock volts and about 2.2ghz and ram is about 1533mhz ish, would it be worth pushing the CPU higher? i use the rig for gaming / video rendering / basic browser in the evening
