don't know if this is the right place for this but i'll give it a go anyway, my problem is this, I have 2 r9 280x's when I install the first 1 everything is great, but when I put the second card in and enable x-fire the pc automatically shuts down, I thought I had a problem with 1 of the cards so it was rma'd but was found to be ok. when I test using unigine it will obviously only test 1 card, it used to recognise 2 but like I said rma'd and every time I try to get things working the second pcie slot is causing issues. when I first built the system I got both cards working but suffered with the screen jumping and shutting down the pc every so often, did some testing and I came to the conclusion it was a graphics card. each card put in the first pcie slot works flawlessly and I get great fps, do you guys think it could be an issue with the second pcie slot ?????
gigabyte GA_Z87X-UD4H
i7770k
16 gigs hyper-x 1600mhz
2 sapphire r9 280x 3gig cards
i7770k
